07-19-2022 03:51 PM
I installed the power adapter and it is still not detected. After playing with it for hours I accidentally left the C wire from the condenser disconnected. Now my nest detected the power adapter. I realized there was a problem when my outside unit would not turn on. When I reconnected that wire, my thermostat no longer detected the power adapter.
07-26-2022 04:24 AM
Hi Dommmy13,
Thanks for reaching out here in the Google Nest Community.
I'd like to check a couple of things for us to further isolate the issue. The only time we are going to connect a Nest Power Connector is when your HVAC unit doesn't have a C wire. It's possible that the connection from the Nest Thermostat and your AC unit is being disrupted by the C wire, thus, getting the connector not being detected.
Check out this link to know more about Nest Power Connector installation.
Let me know how it goes by replying to this thread.
Ryan
07-26-2022 06:40 AM
Ryan, to clarify when I say c wire in my original statement I was referring to the condenser wire as seen in the wiring diagram below. My thermostat does not have a C wire.
07-27-2022 04:24 AM
Hey Dommmy13,
Thanks for the reply.
I'd like to know what happens when you reinsert the wire after you try doing a complete reset on your Nest Thermostat? Also, try to re-strip the wire coming in to the Rc or Rh and test if it is going to detect it.
Ryan
07-31-2022 07:38 PM
Ryan
08-02-2022 12:03 AM
Have a great day.
Ryan
