12-26-2023 03:07 PM
I upload photo of current wiring. It's a Honeywell thermostat. The upper right wire is O/B in case it cannot be seen.
What
12-26-2023 03:08 PM
Also if there is a tutorial on how to install that would be really helpful
12-26-2023 11:31 PM
Don’t bother buying a Nest Thermostat it’s garbage because. Google refuses to make it compatible with Matter. Buy an Ecobee instead. Google does not care about its customers after they’ve bought the junk.
01-03-2024 07:52 AM
Hello everyone,
Welcome to the Google Nest Community! I'd be happy to help you determine if your current thermostat is compatible with an upgrade to the Google Nest Thermostat.
@randomuser99, to provide accurate guidance, could you please share the make and model of your HVAC system? Additionally, let me know if there are any specific features or requirements you have in mind for the upgrade. To sum up, your thermostat's wiring configuration is compatible. Make sure to follow the label when installing the Nest thermostat.
@MagoBuga, thank you for sharing your experience with the Nest Thermostat. It's unfortunate to hear about the compatibility issues with Matter. We appreciate your insights into the product's performance and we'll take it as a feedback. If you have any other recommendations or experiences to share, feel free to start a new thread.
Warm regards,
