12-30-2021 12:04 AM
I’ve had my nest for appx 3 years, I’ve never had a problem with it since installation. Of course now it’s 3am in the winter in Buffalo and it’s not working. My system apparently doesn’t have a C wire but my nest has worked faithfully without one the entire time. Now all of a sudden it’s not turning on until I pull it off the wall and it says the battery is low. I don’t understand why it’s doing this all of a sudden. The wires it uses are y1, g, w1 and Rh. If anyone can help I’d really appreciate it.
01-17-2022 07:54 AM
UPDATE:
I paid appx $300 to have a new wire run from my furnace to thermostat by a heating company in my area that I love. The new wire has a C-wire. Since it was done, appx 2 weeks ago the thermostat has worked perfectly. Fingers crossed it continues this way.
12-30-2021 03:29 AM
I'm having same problems with my thermostat.
12-30-2021 09:33 AM
I'm having similar problems too. With is 4 wire without c-wire. Worked fine for 3 months then system lost power for several days while on vacation. HVAC guy fixed problem and then nest wouldn't hold a charge so he installed a new thermostat and all worked fine. I want my nest back so tried to reinstall but same issues. I recharge by USB and it seems to work but the fan won't go off when temp goes above set point (in heat mode). I read in another post that I could hook the fan wire up to the c terminal but I don't want to mess anything up. Would love to get this working again.
12-30-2021 12:09 PM
I just started having a similar problem. The Nest Thermostat E does not seem to hold a charge. My heating usage patterns have changed and this may be why I noticed the problem. I am now relying on a remote sensor and the outside temps have been in the ############ degree F range. (Oregon snow when we usually have rain). I have charged it with the USB port but that seems to have stopped working as well. I have verified the USB connection to a computer that shows a Technical Info.plist file. All the support info that I have found don't mention this problem. I may end up using an old manual, reliable thermostat. The thermostat has been in operation for about one year.
12-30-2021 12:37 PM
For what it's worth, I read in another thread that the thermostat seems to reset and start working when connected to a computer and is "mounted". Mine seems to be working now. But time will tell if this is a "fix" or a "fluke".
12-31-2021 07:22 AM
You mean connect it to a computer then plug it back into the wall??
01-17-2022 05:09 AM
What does “connected to a .. & mounted” mean?
01-17-2022 08:54 AM
Connect to your computer with a USB cable. Mounted means that you can see the device in Windows File Explorer as a drive letter. (Mounted is a Linux term. Not sure what the Windows lingo is).
05-02-2023 07:56 PM
External drive if anyone’s reading.
Interesting concept. I might try that. I’ve been having to charge mine a few times a week. Driving me nuts!
05-03-2023 07:45 AM
I gave up on mine and got an Ecobee thermostat. 100% better and no problems so far.
05-06-2023 09:54 AM
You replaced the Nest after installing a C-Wire? The C-wire didn’t work out? I’ve been thinking of having running one myself.
05-06-2023 04:10 PM
After running the wire it kept the power on/charged but the lack of power and the damage it did without the c-wire basically fried it. I couldn’t connect the Wi-Fi again. So in effect it was just a normal thermostat. I dealt with it for about a year then said eff it and went with my ecobee. Love it.
05-07-2023 05:53 AM
Oh wow. I have two of them since 2018. $500 … what a waste.
Thanks for the info!
12-31-2021 08:45 AM
Yes. When I connected to a power only charger, I didn't get any flashing lights on the display. Then I tried a computer USB connection. When I did that, the file manager opened up and showed a .plist file. I looked at that and it contained my device serial number and other info. That indicated that I didn't have an USB cable problem. I put the thermostat back on the wall and it worked all night like it usually does. I discovered the other thread when I searched for USB charge in this forum. (
https://www.googlenestcommunity.com/t5/Nest-Thermostats/Nest-Learning-Thermostat-3rd-Gen-not-chargin...). I'll keep monitoring my thermostat to see if the "fix" continues to work.
01-01-2022 08:05 AM
Nest E was a free promo from my power company. Installed in Sep 2020. There is no C wire connected. It operated with no problems up until our recent cold snap. And the furnace was running more than normal. The remote sensor was also being used more. I started getting offline messages on my app and it was not finding the remote sensor. The "fix" that I found in another post is a red herring. I find that connecting my thermostat to a USB charger for a short while will allow it to function normally for a few hours. I suspect that the battery is failing. Not sure of my next steps.
01-03-2022 12:31 PM
I did a factory reset last Thursday 12/30 that didn't resolve the nest issues so I called Nest customer service. The guy seemed like he knew what he was doing and verified that the unit should work even without a C-wire. Then he walked me through some troubleshooting steps including switching the G and W1 wires in my 4-wire setup. He came to the conclusion that my thermostat is working properly and I need to get a nest certified technician out to check all the settings. I already spent $365 for a HVAC tech service call including the new old-style (not smart) thermostat. I won't pay for another service call. Nest was working fine for 3 months, then lost power for a few days and didn't work anymore with the Nest but works fine with a dumb thermostat. My logic says it's a thermostat problem. I'll try to charge the nest via the usb port on my computer and re-install one last time before sending my nest to the landfill. That would be a bummer.
01-03-2022 02:36 PM
Google seems to think that I don't need a C wire. But all the reading that I have done suggests that I do need a C wire. (My Nest has worked fine for over a year without a problem). I ordered the Nest C wire device. I should get it and install it in the next couple of days. I will update with my results. And for the record, I suspect a flaky battery on my Nest.
01-07-2022 10:44 AM
Mine has worked ok, not perfect. Get messages that my heater stops/starts a lot. It’s cold in KS, in the teens for days. Yesterday said it needed to shut down to chg. Didn’t work. I too suspect a dead nonrechargeable battery, but troubleshooting wants me to do all kinds of heater cks. The Nest is at least 3years old, going to replace it with a cheap thermostat today to get heater running, ordered Amazon Alexa compatible thermostat today to give that a try. From what I can tell, these smart thermostats need the c-wire, I sidestepped that on the Nest, but ordered the adaptor for the new Amazon.
01-17-2022 07:54 AM
UPDATE:
01-17-2022 08:04 AM
I wish they told you the nest REQUIRES a c-wire when you buy it. Suggestion nest: ADD THIS to the box “works best with c-wire connection.” So people know and don’t run into a problem where their furnace stops working when it’s 0 degrees out.
02-08-2022 05:54 PM
Mine works great without C wire.
02-08-2022 06:56 PM
Mine did too for the first 2 years-ish. Then it didn’t.
02-09-2022 06:40 AM
Same here - 2 years good, and then not. And no way to troubleshoot with Nest involved. I'm done with companies that don't offer support for their products.
01-17-2022 11:26 AM
Yeah why does it only happen when it’s freezing out??
01-17-2022 12:09 PM
As I understand it with my limited electrical knowledge, when the thermostat switch is open, the Next can draw power from the furnace control to charge the battery. When it calls for heat, the switch closes and the Nest can no longer get power for charging. When the battery charge drops too low, the Nest drops WiFi and bluetooth connections to conserve power and allow the thermostat to function as much as possible. With a marginal battery, the extra furnace run time discharges the battery too much and the connections drop. Eventually the battery regains enough charge to function normally.
I suspect that this may be a problem in the summer with AC, but I don't use the app or remote sensor enough to know.
A big Nest problem for me is the lack of being able to get real time info on the actual status of the thermostat internals such as battery voltage.
01-17-2022 01:11 PM
Thanks. We hardly use it in the summer it’s only a Winter thing in the Northeast and I don’t know it’s on it’s off it’s on it’s off unpredictable and that’s not good. I’m going back to buying an old school thermometer
02-08-2022 06:54 PM
Lol cuz that’s when we need it most.
01-17-2022 09:09 AM
I received the C wire device. But the wiring in my furnace does not match any of the installation diagrams exactly. I have other things to do, so this project is on the back burner. Our cold snap is over and the thermostat seems to be working OK. The furnace doesn't run as much and we are not using the remote sensor.
When I have some spare time, I will try to figure out the C wire adapter and install it. I don't want to run a physical C wire from my furnace. If I can't get this to work, I will eventually replace the Nest thermostat with a more conventional model that doesn't need the C wire.
01-17-2022 10:58 AM
I had a tech do it. He took the old wire out completely and ran a new wire. Striped the wire and connected it. That’s probably your best option.
01-17-2022 11:21 AM
Yes I don’t want to have to do the C wire addition. I’d rather not use the wifi system in that case
01-17-2022 11:45 AM
It didn’t have to do with the Wi-Fi. It gives it power from what I understand. It has to do with it charging and staying on.
01-18-2022 10:00 AM
My nest thermostat has an 8 wire connection WITH a C-wire and has been installed for 3+ years without an issue. The past couple of weeks it has been turning off by itself with a red flashing light and is unresponsive. The only way to get it working is to manually charge with a usb, but it only holds charge for about a day. I have checked the wire connections and used a multimeter to ensure that the wires have correct voltage and everything is good. Is it a possibility that the battery is shot and unable to recharge even though C-wire is connected? This nest has the lithium ion battery.
01-18-2022 10:05 AM
That would be my guess?
01-18-2022 12:34 PM
That seems like a reasonable guess. As I've said before, it is extremely difficult to get real time information about the state of the charge and other useful parameters. I think you can find replacement batteries and instructions online.
01-18-2022 01:36 PM
Yeah so far the new wire with c connection has solved the problem. *knock on wood*
02-02-2022 05:32 PM
I have a Nest cam that is not even 6 months old says battery isn’t holding charge what can you do for me to fix this
02-02-2022 06:01 PM
Good luck getting Nest to respond. I finally bought a cheap thermostat to get heat back in my house.
02-03-2022 05:22 AM
I tried charging the next through the USB on my computer. It seems like it charges but I haven't reinstalled to test. I'm leary after reading all these posts and have lost my enthusiasm to try to get the Nest E thermostat working. The 30 day warranty tells me that Nest/Google doesn't think much of their product and the 1 hour call to tech support wasn't worth my time (or theirs). I may buy some other WIFI thermostat down the road but will not be a Nest product.
02-03-2022 06:18 AM
My bet is you’ll have the same problem with another Wi-Fi thermostat. Your best bet is to install the c-wire. Mine is still working like a charm!
02-06-2022 09:18 AM
You are probably right Lindsay. My issue with that is I'm in a condo with thermostat wiring in the walls. Someone before me spliced the thermostat multi-wire cable in the wall somewhere (brown jacketed cable at the furnace and yellow jacket at the thermostat) and only connected the RWYG wires. I could install a C-wire adapter kit but I'm honestly irked with Nest support and 30 day warranty and don't want to invest any more time or money in getting the Nest to work. I could install the adapter and then it ends up being that my Nest battery is bad. Maybe I'll get my enthusiasm back in the Spring.
