Need help. Anyway to hook this up to basic nest thermostat?
Znel52
  • Anyway to hook up a nest thermostat with this wiring? The site seems to say it's compatible but I couldn't get it working right.
  • https://ibb.co/xLFMtK2
Hello Znel52,
It's nice to see you here in the Google Nest Community with your thermostat's wiring set up. I'd be happy to take a look at its compatibility with the Nest Thermostat.
Most heat pumps work with the Nest Thermostat, but seeing how the wires are installed, two wires are connected in one terminal. To be sure, can you also share with us a photo of your system control panel showing how these wires are being installed?
