3 weeks ago
Have a gas forced air heater; no AC; old thermostat worked perfectly. Hooked up the simple 5-wire (with C) from old thermostat to new Next (basic model). I can't get ANYTHING to work (batteries are okay) - I'd be happy with manual operation just to get it going. What could be wrong?
3 weeks ago
Here are old and new (Next) wire connections.
3 weeks ago
I think I resolved the problem. I had to trick the on-line setup steps by pretending I do not have a O/B wire even though I do (which enables switch from heat to cold). Saying I had an O/B wire caused an error saying 'contact Nest support'. That error message seems to happen if you click on any of the 'other', non-standard wires. Hope this resolution helps others.
3 weeks ago
Hey BBGULETZ,
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
