09-01-2022 07:10 AM
Hi, there is no power to my Nest receiver so I am getting the H71 error code. Can anyone help with how to get this fixed?
09-02-2022 05:56 AM
Thanks for letting us know @Kay3
Could you tell me please when did the situation start occurring first and when was the thermostat installed?
Also, please answer the following questions:
Are there any lights on the Heat Link? Does the boiler activate when calling for heat by pressing the Heat Link's button to activate Manual Mode?
Are you seeing any wiring report or message on the thermostat and/or the app?
Have you had any recent power cuts in your area? If yes, has the power been restored?
Have you recently had service or maintenance on your electrical, plumbing, or heating system?
If yes, how long was the power off for? (Be specific.)
Could you tell us please if you've checked on the breaker switch and fuse box?
Any blown fuse in there? Have you tried to turn the breaker switch off and on again? Any difference?
09-04-2022 06:41 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
09-06-2022 06:44 AM
Hi @Kay3. Do you still need our help? Keep us posted.
09-09-2022 06:49 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
