01-27-2024 08:37 AM
All the labels on my thermostat are not listed on the Google Nest compatibility checker. Would someone be able to help me determine whether my thermostat is compatible?
There are following labels on my thermostat:
R W/Y Y/A GI Gm Gh C Rs Sc SB PS
Thanks
02-07-2024 09:00 AM
Hello AXS1510,
Thanks for reaching out. It seems like you have a set of labels on your thermostat that might not be explicitly listed on the Google Nest compatibility checker. Don't worry; we can still try to determine compatibility based on the available information.
Typically, thermostat compatibility depends on the wires and their functions. But it seems like your thermostat has the standard wires for power, heating, cooling, an indoor fan, and more. The labels Rs, Sc, SB, and PS might be specific to your system but are not standard in the context of thermostat wiring.
To determine compatibility with the Nest Thermostat, share with us the photo of your thermostat and the make and model of your HVAC system.
