11-01-2021 02:31 AM - edited 11-01-2021 06:53 AM
I bought a used Nest 3rd Gen from CEx (This may be where the problem arises! 🤔 )
Trying to install it in place of my current thermostat:
Even with the screen unplugged from the connection ring part, no life even at the Heat Link. I tested again, T1 and T2 connected to the screen's connection part the Heat Link is dead. Unplug the T1 or T2 and it's alive again.
Any ideas??
Thanks
12-01-2021 07:45 AM
Hey @b3nb123,
I'm sorry to hear it wasn't a smooth installation and use of the thermostat, but I'll do my best to assist you.
12-06-2021 09:00 AM
Hi, I wanted to check in.
Do you need any further assistance? If so, make sure to let me know.
12-10-2021 06:16 AM
Since there haven't been any further replies I will go ahead and close this thread.
If anything comes up that you need assistance with, make sure to reach out on any of our support channels.
AlexD
