Nest E still short cycles 2 wire oil burner after adding Nest Power Connector
acb0173
Nest E frequently short cycles my 2 wire oil burner (heat only) furnace. Since I have no available C wire,  I THOUGHT the answer was to add an external 24v transformer and the Google Nest Power Connector. No dice. It still frequently short cycles. Is it time to abandon the Nest E and get the Ecobee?
Ryan_G
Hope this helps!
Kind regards,
Ryan
