Nest Fan Control
ilios
Is there a way to run the fan manually permanently? It seems like there's only the timer options. The longest I saw was 12 hours 😕
MelbaDT
Hey ilios,
Thanks for reaching out to the Google Nest Community.
If you have a system with a dedicated fan wire, you can manually turn on the fan with the app or your thermostat, or set a fan schedule. For example, you can set the fan to run all night and automatically turn off in the morning.
To know more about fan controls, please check this out: https://bit.ly/2KDDJJw
Hope this helps.
Melba
MelbaDT
Checking back in should you have more questions about this.
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
