Nest Heat link dead, power to it but no led lit
jonalderman
My Nest Heat link module is dead.
Power is being supplied and has been checked at 240V, no breakers tripped no fuses blown.
The Heat link led is not lit and of course this means the thermostat is not working so no hot water or central heating.
Can I ask you how do I organise a replacement under warranty asap?
Hi Christian
Thanks and yes, Heat Link replacement was received after 5 days, installed and works fine.
8 REPLIES 8
Frustratedddd
Easiest way is to ring Nest
Many thanks but in the meantime I found the Warranty claim form and have submitted one. Hope that works
That's up to you, but a phone call will normally get the replacement to you within 24hrs, I will be interested to see how long that way take.
CristianC
Hello again. Just checking in. How's it going with your Heat Link?
Hi Christian
CristianC
Awesome. I'm glad to hear that. If anything comes up, let me know.
AlexD
Hi. Since the situation has been resolved and there have been no further replies I will go ahead and lock this thread.
If anything else come up that you need assistance with, make sure to reach out on any of our support channels.
AlexD.
CristianC
Hey @jonalderman,
I'm sorry for the late reply. Did you manage to get your Heat Link replaced? Let me know if I can help.
