Nest Not working (rh wite no power) now has blank screen
MukeshPatel
Got no power to Rh issue. Also seen e74 error message in between. Now there is no power and screen is blank.
@MukeshPatel, to test for proper power, you need a multimeter. Set the meter to measure AC voltage. Place one lead on R and the second lead on the C wire. You should see 24VAC +\- 5VAC.  If you see less than 20VAC your system needs service to replace the step down transformer.
AC Cooling Wizard
