Nest Power Connection for Heat Only wiring configuration
Lgranlund
I am connecting a nest power connector to a heat only system to a Wirsbo zone controller.  I don’t know what to do with the white C wire on the power connector.  Does it connect somewhere and if so where?
@Lgranlund ,
On the left side of your zone controller you should see R-C-ES-ES. This is where the Common and R are coming from your HVAC transformer.
AC Cooling Wizard
@Lgranlund ,
AC Cooling Wizard
Yes, I see this.
How many zones do you have active?  Secondly, are there any unused wires in your thermostat cable?  If so connect the unused wire to C at both ends and leave power adopter in the box it came in.
AC Cooling Wizard
