Nest Temp Sensors Low Battery - but which one? All say battery status as “OK” in technical info
Sbthu
I’ve been getting a notification that one of my Nest Temp Sensors has a Low Battery - but which one? All say battery status as “OK” in technical info in the app.
6 REPLIES 6
Hello Sbthu.
Thanks for posting here about one of your Nest Temperature Sensors showing a "low battery" message. I understand it's confusing to tell which one is which, but I'd love to know more about this.
Could you provide a rundown of all the steps you've tried? How many sensors do you have? Also, how often did you get the low battery message?
I was able to figure out which sensor by holding down (long press) on the notification. Once I did that, I could see it was the bedroom sensor.
Hi Sbthu,
Sounds great! Thanks for the update on what you've done to have your concern rectified — give yourself a pat on the back for a job well done!
It looks like we can consider this one finished, so I will lock the thread in 24 hours unless I can help out with anything else.
No other questions! Thanks!
Hello Sbthu,
Perfect! So I'll lock this thread in 24 hours. If you have any other concerns or questions, please feel free to create a new post.
