Nest Thermostat Cooling in Heat Mode (No heat pump)
ksylvester
Basically the title. It's a new install, I've triple checked the system is compatible. I have a conventional gas furnace. When I turned my system in after install, it shows that it's heating the house to 71F but the registers are blowing cool air.
Please help this chilly OP
ksylvester
I can't! I took a photo in the app and it deleted it during setup
Ryan_G
Hope this helps!
Kind regards,
Ryan
Post a picture of the original thermostat's wiring here?
Can you take a picture of the terminal block on the control board in the furnace/air handler?
Ryan_G
Hi ksylvester,
Thanks for reaching out and we're sorry to hear about what's happening.
I'd like to jump in here and check if you've seen Patrick_Caezza's response about taking a photo of your wiring.
Let us know how it goes by replying to this thread.
Thank you for always helping us, Patrick_Caezza.
Ryan
