10-20-2021 11:16 AM
Hi my Nest E thermostat is flashing red for a few hours connected to the wall via USB , but still stubbornly wont switch on , what shall I do?
10-20-2021 11:41 AM
Isn’t usb only for charging?
10-20-2021 11:45 AM
Yes it is only for charging but it's just doing it very very slowly, if at all - the red light is flashing
10-20-2021 11:47 AM
Try to reset it, push and hold it
10-20-2021 11:52 AM
I tried it’s not working
10-23-2021 12:59 AM
Hi @Daniherenow , I would be happy to try and assist.
It is possible that the internal battery is drained so we can try to recharge it directly.
Hold the stand with one stand and with the other grab the rotating ring on the display. Pull it towards you, it will detach from the stand. On the back you will notice a micro-USB port. Use that to connect the display to something like a phone charger and let it charge for 90 minutes.
Once done place it back on the stand and see if it turns on. Make sure the stand is connected to power, the thermostat requires to have a constant power supply to function.
If it does not make sure to also try a different cable and adapter if you have any on hand.
AlexD
10-23-2021 01:04 AM
Thank you Alex I was in a chat with Google support and they are shipping a new thermostat it didn’t get any power to it’s base
10-23-2021 01:15 AM
It is great to hear you managed to get in touch with my colleagues to get things back on track. If anything else comes up don't hesitate to reach out to us on any of our channels.
