01-06-2024 06:37 PM
I've had my Nest thermostat for 5 months. All has been perfect up until around a month ago when I got a low battery display on my thermostat. I replaced the batteries and it said the batteries were still low. I assumed the batteries must have went bad in my drawer. I went out to the store and bought a new pack of batteries, same issue. My thermostat is still saying low batteries with a fresh set. I hooked a multimeter up to the batteries and they say 1.41 volts. Inside the home app it says the battery voltage is 1.23 volts. When I look at the battery voltage directly on the thermostat display, it says 1.43 volts. I have made sure there is no dirt blocking the contacts for the battery on the backside of the thermostat. My thermostat is also connected to a C wire. When looking at the nest display it confirms the C wire is connected and shows a VIN of ~38 volts. Does anyone know how to get rid of this low battery display?
01-10-2024 08:19 AM
Hi Dagdandris,
Thanks for reaching out and for being a step ahead of us. It looks like you have the Nest Thermostat 2020. To confirm, what type of batteries did you use for your thermostat?
Try putting back the old batteries and check your thermostat battery impedance. Impedance is an indicator that the batteries need replacement. To do this, on the thermostat display, please go to Settings Battery
Battery Status.
If impedance is still higher than 1500 mΩ, put back the new batteries.
Please keep me posted.
01-10-2024 08:35 AM
I previously had Energizer batteries in my thermostat. However I threw them away. I now have brand new Amazon Basics batteries in them. When I check the impedance it says N/A.
01-12-2024 02:19 PM
@Dagdandris, If you've replaced the batteries in your Nest Thermostat with fresh ones and are still experiencing a low battery display, there are a few potential causes and troubleshooting steps you can try:
I appreciate your help, Jenelyn.
