Nest Thermostat Not Showing Cooling Option
shoyu2015
Help! I installed a Nest thermostat for my A/C only thermostat but it's only showing a heating option and won't register with the A/C unit to blow out cool air. My wiring at the thermostat is a white, green, and red wire. Based on the installation through the Nest app, I had to install a power connector so I did that, but at my A/C control panel, there were only Y1, G, R wires. Is this a wiring issue? I tried wiring the white wire to both Y (to match the control panel) and W to match the wiring, but both configurations won't register cool air.
Tried wiring the white cable to Y (to match the control panel) and W to match the wiring but both won't register cool airTried wiring the white cable to Y (to match the control panel) and W to match the wiring but both won't register cool air
@shoyu2015 , When you installed the Nest Power adapter, you should have disconnected the white wire from the furnace/air handler  control board and connected it to the Y*W wire of the Nest Power Adapter then disconnect the Red wire from the air handler and connect to the R wire of the Nest Power adapter.  Then the take the group of three wires and attach the R to the control board R, the Y*W to the Y1 on the control board and the C to to the C on the control board.  Did you remember to download a software update for your Nest Thermostat? Your thermostat needs to latest software in order to be able to recognize and use the Nest Power Adapter.
AC Cooling Wizard
Thanks! Did both and realized I had to update the wiring configuration. Problem solved 🙂
Thanks for posting in the Google Nest Community forum. I'm glad that the issue with your Nest Thermostat is now resolved. Please feel free to create a new thread if you have any questions or concerns, as I'll be locking this thread after 24 hours.
