12-26-2021 06:05 AM
Having issues the last couple weeks with my nest starting the heater manually when we turn the temp up as well as it seems to not be heating over night. During the day it heats and maintains temperature fine but when I wake up at 5am the house will be 56° even though the nest is set to 67. I’ve tried turning the furnace off and on as well as the nest and with both the furnace itnites and shuts off 3 times then doesn’t ignite again. Yet after about 7am or so the heat kicks on just fine. It’s not a schedule issue because I’ve changed the schedule times and temps multiple times. When I try to turn up the heat manually it says somethin like “in 1hr 30min” but doesn’t ever call for heat when the thermostat is turned up.
