11-22-2021 05:30 PM
Hi! I just installed my new Nest Thermostat and I think it mostly works I just think i have a bit of trouble matching the wires with their alternate names.
So what I had connected on my old therm was :
1.W2 / AUX
2.G
3.W / OB
4.C
5.Y
6.R
Most of them are exact match so no issue here. The only ones that puzzle me are W2 / AUX and W / OB. On my nest termostat I have a slot W and an OB. So do I understand that actually my W2 wire goes into W, and then my W goes into my OB? Sorry if it sounds really dumb! I say it mostly works because the system defaults to my Auxiliary Heat it seems (the heat pump's motors dont rotate outside as they normally do).
Thanks for your help.
12-06-2021 08:58 AM
Did you find a solution to you issue? I am experiencing the same.
