11-21-2023 09:25 AM
We have a 2 heat 1 cool heat pump with auxiliary heat and I want to confirm if I can use Google Nest Thermostat?
We really don't need auxiliary heat, and I believe we do have C-wire
I want to to make sure Google Nest will work with our system before we purchase
Here's a pic of wiring if it helps
https://i.im.ge/2023/11/20/AESY80.thermostatwiring.jpg
Teresa
11-25-2023 07:44 AM
Hi teresli,
Thanks for posting here in the Community forum and for showing interest in our Nest Thermostats. Fortunately, your thermostat wires are compatible with our Nest Learning Thermostat 3rd generation and should be wired to the Nest Learning Thermostat as shown:
Also, here's a guide for the installation and setup of a Nest Learning Thermostat.
Let us know if you have any other questions.
