03-19-2023 07:45 AM
Hello , since couple of days I’m running into battery issues with nest thermostat. Verified power input all looks fine, also charged device using USB cable but it is not working and always show this message “Nest Thermostat restarts in order to recharge its battery” goes into recursive mode.
03-19-2023 08:50 PM
How is the Nest Thermostat wired?
Does it have a C wire?
What type of System do you have? Furnace, Heat pump, or radiators??
03-19-2023 09:31 PM
Patrick, C wire is plugged in and its furnace. This behavior started since 5 days. Nest doesn’t get charged over USB and restarts
03-20-2023 05:26 AM
03-22-2023 06:48 AM
Any help here is much appreciated, issue is not resolved
04-15-2023 03:22 PM
Hello folks,
Thanks for the help here, @Patrick_Caezza.
@Rishindra, I know it has been a while, but I wanted to stop by and see how I could help. How's it going with your thermostat? Is it still not holding its charge? If so, please check your thermostat's power readings under the Technical Info settings.
04-18-2023 03:45 PM
Hello Rishindra,
04-19-2023 03:50 PM
Hi Rishindra,
