Nest learning thermostat blowing heat air when set to cool after 5 minutes. Wondering about the wiri
Edwardqu
zoeuvre
Hi Edwardqu,
Thanks for reaching out to us, and I'm sorry to hear about the situation. Please answer the following:
  1. What type of Nest Thermostat do you have?
  2. Who installed the Nest Thermostat?
  3. Did you try using the Help Center or troubleshooter before contacting support? If so, which steps have you tried already?
  4. Can you help me with a photo of how you connected the thermostat wires to the Nest Thermostat base?
  5. What is the make and model of your HVAC system?
  6. Did you  turn off the power to your HVAC system?
    • Are the breakers turned on?
    • Did you recently experience a brownout or blackout?
    • Did you have any construction or maintenance work done on your home?
  7. Do you see any message or code on your thermostat?
I'll look forward to your responses.
zoeuvre
I want to check if there might be anything else you needed on this or if you had any other questions. If there's more you need, just let us know.
Dan_A
Hello again,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you need assistance or want to discuss topics, feel free to start a new thread.
Sincerely,
Dan
