09-13-2022 07:13 AM
My thermostat is off-line on the app and says low battery I did not think there was a battery how to fix so will work on app
09-15-2022 03:58 AM
Nest thermostat uses the voltage from your system’s wires to keep its internal battery charged. If the power to your system is switched off or there’s a blackout, the battery has enough capacity to keep working for a while but if not charged the battery will eventually drain.
Depending on the light colour, follow these steps:
Troubleshoot when your thermostat won’t turn on - Google Nest Help
09-19-2022 10:44 PM
@David_K, thanks for the help!
@Ninacolada821, how's it going with your Nest Thermostat? Still need our help?
Edward
09-22-2022 10:51 PM
Hi Ninacolada821,
Edward
09-27-2022 09:40 AM
Hey Ninacolada821,
Edward
