01-05-2024 07:07 PM
I have a nest smart thermostat I purchased 6 months ago. Today it failed to connect to the wifi and I discovered that the battery level was low. I reset the router then the furnace and it still would not charge. I tried to charge manually via the usb but it does not charge. As this unit is 6 months old it should be covered under warranty for replacement right?
01-09-2024 08:10 AM
Hello Orangeman,
I'm sorry to hear about the issues you're experiencing with your Nest thermostat. Given that you've already taken steps like resetting the router and furnace, as well as attempting to charge it manually via USB without success, it seems like you've covered the basic troubleshooting steps. Here are a few additional steps you might consider:
Let us know if you have more questions.
