Nest temperature sensor fails to connect to thermostat-E
tito77
I am unable to make the connection work between the Nest Temp Sensor and Thermostat-E.  The thermostat is functioning and connected to the internet. I tried to add the temp sensor using Nest App, Add products.
After scanning the Q-Code, a message appears stating the I need a Thermostat-E sensor. The Nest App is on IOS phone. I tried scanning the Thermostat Q-Code again, but that is already installed.  Do I have to restart installing the thermostat again, It is a lengthy process.
I have bluetooth turn on my IPhone. Should I try to find if my Iphone will display the thermostat pairing, or is having Bluetooth on, good enough?
Ryan_G
Hi tito77,
Thanks for reaching out and we're sorry for the delay.
Another thing to do is to remove the battery from the Nest Temperature Sensor for at least 30 seconds and make sure it is near the thermostat when you do the pairing. Also, turn on your iPhone location services and Bluetooth while doing it.
I hope it helps.
Ryan
Ryan_G
Hey tito77,
I just wanted to follow up and see if you're still in need of help? Please let us know, as we would be happy to answer any questions you may have.
Ryan
clinicus
I have the same problem and I do not see an option to add a sensor to my thermostat
Ryan_G
Hope this helps!
Kind regards,
Ryan
