Nest thermostat compatibility with heat pumps
RichaHenderson
I have a three stage heating and 2 stage cooling system with a total of eight wires.
I have a brown wire on Y2 and
E and Aux jumper together
I have R &RC Jumper together
I have an orange going to the O and the B
I have a yellow going to y
I have a green going to the G
And lastly I have a black wire going to the C
Any help would be greatly appreciated or I guess I’ll return the thermostat
Your system is only compatible with the Nest Learning Thermostat 3rd GEN.
Post a picture of your current thermostat's wiring and I'll provide a wiring list.
6 REPLIES 6
I am not seeing a box to check or uncheck to allow me to attach a picture.
can you please share more details on how I can attach it?
Use the camera icon in the editor
Patrick_Caezza, I attached the picture on Saturday. Are you able to send over the wiring list you mentioned in the post on 12/2/21?
Has the picture come through? It looks to me like it is posted so, I hope you can offer some guidance
