11-03-2022 11:27 PM
I received a nest thermostat as a gift. (sku ga02083-us) It is not a Nest learning thermostat. I have a heat pump with a propane emergency/aux back up. I've looked at quite a few forums and videos and it doesn't look like the thermostat I have will work with my system. Can somebody help verify if that is the case or not.
11-04-2022 04:54 PM
Do you have a photo of your current thermostat wiring set-up? Kindly reply the photo to this thread if you do.
11-08-2022 10:10 AM
Hi Crs,
I just wanted to jump in real fast to see if you saw eveluna's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
11-11-2022 02:21 PM
Hi Crs,
Edward
11-11-2022 02:42 PM
This is the set up on my current thermostat.
11-11-2022 07:15 PM - edited 11-15-2022 02:44 PM
Hi Crs,
Thanks for the response. I'm sorry to hear that you're having an issue with wiring your Nest Thermostat. The model that you have works with single stage heat pumps with AUX heat. If you haven't yet, try the following wiring:
White - W
Red - R
Orange - OB
Yellow - Y
Green - G
C wire - C
You can also click on this link to learn about the systems that would work with the Nest Thermostat.
Edward
11-14-2022 07:20 PM
Hey Crs,
Edward
11-14-2022 07:24 PM
I don't know if I have a single stage or dual stage heat pump. There are extra existing wires that I don't know where they would connect to on the nest thermostat. Still doing research.
11-15-2022 02:45 PM
Hi Crs,
Thanks for the response. If you have access to the control board of your system, please share a photo of the wiring so we could take a closer look.
Edward
11-15-2022 03:04 PM
I tried attaching a photo but for some reason I can't figure out why it won't let me. Here is a link to my existing thermostat.
11-16-2022 06:20 PM
Hi Crs,
Thanks for sharing another photo. Have you tried the wiring that I sent before? Keep us posted.
Edward
11-20-2022 10:24 AM
Chiming in to see if you still need assistance with this. Let us know if you have additional questions ― we'd love to help.
Mel
11-21-2022 10:25 AM
Mel
