Nest thermostat does not follow schedules or temps I set it to
ViaSwiss
I have a new home build and had the builder install a refurbished Nest thermostat. I've used an EcoBee in the past with zero issues.
I have schedules set of my Nest, however the system only seems to work correctly 20% of the time. The thermostat will show that it is following it on its face, however most of the time the temperature does not ever change. This is both with heating and air con.
If I try to manually adjust to the temperature, it shows that it wants to change to that temperature, however, rarely does it actually change the temperature of the home. Its only a 1,500 sq ft home too.
Hi ViaSwiss,
Thanks for reaching out. A few questions: what type of Nest Thermostat  do you have? You can visit this link to check what type of thermostat you have. Do you see any messages or codes in the app or in the actual thermostat device?
Hello folks,
Thanks for assisting the user, Jenelyn.
@ViaSwiss, I'm checking back in — how's it going? Still need our help?
Hello ViaSwiss,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
