2 weeks ago
Old thermostat uses Y, G, R, C, W, W2. Completed setup and said red wire wasn't connected (it was). Stripped wire, reset device, added new device and now it says something went wrong and try again. It won't let me complete setup.
Error E294
2 weeks ago
Talked to Google and got it figured out
2 weeks ago
I had this same issue. What did they tell you that fixed it?
2 weeks ago
Reset on the thermostat device, not the app.
2 weeks ago
OK. Thank you.
a week ago
Hello folks,
I wanted to ensure that everything is covered here.
@jls426, I appreciate you posting and updating us on your efforts to address your concern finding a fix.If there’s anything else I can help you with, please let me know.
@Oregonian, I wanted to see if you are still in need of any help. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
a week ago
I'm good. Thanks.
a week ago
Awesome! I'm glad to know it was sorted out. It looks like we can consider this one complete, so I will lock the thread within 24 hours unless I can help out with anything else.
a week ago
Yes everything is working for me
