4 weeks ago
replacing a thermostat that is battery operated. I have a 2nd gen nest thermostat. i can buy from amazon a 24 volt 2 wire that could power the thermostat. But how would i wire with the red and white cable going to the fireplace?
3 weeks ago
I wanted to follow up and see if I could be of any help. I found an article with more details on compatibility. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
3 weeks ago
Thanks Jake
So i hooked up the the white wire to W1 the read to RH , this is from the fireplace
24 volt to C and the other wire to RC
The Nest works but sometimes it does not recognize RH which is the Red from the fireplace.
When i put a tester on the wires from the fireplace there is no power coming from the fireplace
It only works if the i add the 24 volt cable to it. I did research this from youtube . Which it should work. But am stumped why the red does not show up.
2 weeks ago
I am sorry to hear you are still having trouble. I wanted to check in with you, as I found an article with some troubleshooting steps for the wire not being detected. Please let me know if that helps, or if you have any questions from here.
2 weeks ago
Well it is working with Google and there seems to be no issue now. So all things are good
2 weeks ago
I am glad to hear everything is working properly from here. I am going to go ahead and leave the thread open for 24 hours in case you do run into any questions/ issues.
