Nest thermostat how to change cooling temperature to go lower it’s stuck on 78
Heathergavit
How do we change the nest thermostat temperature to go lower the AC for some reason is stuck on 78° and I cannot get it to go down lower
CBFox
Is it possible that you have Eco mode turned on?  That could explain the problem.  If so, turn Eco off to get the Nest to follow your schedule.  (Or you could lower the Eco temperature setting.)
MelbaDT
Thanks for chiming in, CBFox.
Heathergavit, sorry for the delayed response but do you still need help with this? If yes, what specific type of Nest thermostat is this? Have you tried CBFox' suggestion? If yes, how is it?
Melba
MelbaDT
Checking back in — how's your thermostat now?
Melba
Ryan_G
Hope this helps!
Kind regards,
Ryan
