Nest thermostat installation help
Can1208
Hi...I have a Honeywell thermostat that controls a dual fuel unit. Wiring g diagram attached. I need assistance wiring a new nest learning thermostat 3rd gen with a blue bubble level.
Thanks!!
EdwardT
Hi Can1208,
Thanks for reaching out. Since you have a dual fuel system, you will need to have a trained professional set up your thermostat. It’s important for a professional to assess the requirements for your specific dual fuel configuration since choosing incorrect options for a dual fuel system can result in damage to your system. Contact a local pro.
Edward
Can1208
Thanks for the reply. That does not make much sense, since I installed the older Honeywell dual fuel thermostat myself. If I have to pay a pro installer several hundred dollars to install it, it negates the reason I bought the thermostat - to save on heating and cooling bills.
Jhonleanmel
Mel
EdwardT
Hi Can1208,
Thanks for the response. I understand that you want to save money by installing it yourself but having a Pro to install it will make sure that you're system is configured correctly and prevent damage to your system.
Edward
Jhonleanmel
We appreciate your help here, @EdwardT.
@Can1208, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
