Nest thermostat lost connection to WIFI
GeoffWyatt
Yesterday, out of the blue my nest thermostat lost connection with WIFI and now wont find any networks.  Allmy other WIFI devices working fine but have reset router anyway.  Also tried resetting the thermostat with no luck.  Any ideas please?No WIFI.jpgBattery.jpgBase.jpg
12 REPLIES 12
accavazos
I’m having the same issue. Mine started 3 days ago.
GarrettDS
Sorry for the late response, but I wanted to drop in here to help.
I understand that wifi issues in regards to your thermostat can be confusing but I definitely wanted to stop by and see how I could help.
Just wanted to double check to see if you were still needing help on this? If so, what troubleshooting steps have you tried?
Please let me know.
Garrett DS
Hi Garrett,
Thanks for getting back to me.  Definitely still not working.   Firstly I rebooted my WiFi router.  This made no difference and all my other wireless devices were working fine.  I then did a reset on the nest thermostat itself.  I also searched for networks on the nest and it did not find one.  My phone for example finds 5 networks.
thanks,
Geoff
GarrettDS
Hey there @GeoffWyatt, @accavazos, and @Kenzdad
Sorry to hear you're all having the same issues with your thermostat. Is there any error message that you are seeing on the display? I know some of you have tried a factory reset on your device, but if you have not tried that, I would suggest giving that a try as well.
I would also suggest reviewing this article as it will have some great troubleshooting steps in it as well.
Please let me know if you have any further questions.
Garrett DS
No error messages showing,  I have just gone through your troubleshooting article with no luck only now I have removed the thermostat (following the advice) from my home app and can’t re add it without the WiFi connection.  Is there somewhere I can escalate the complaint as I don’t seem to be getting any closer to a solution?
Hey GeoffWyatt,
I wanted to reach out and let you know that I have escalated your issue to a higher team, and they will be in touch with you very shortly. Please be on the lookout for that, and let me know if you have any trouble seeing that from our Team.
ai
Hello ,
Sorry to hear that you've been experiencing such frustrating issues with your thermostat! I've gone ahead and created a case for you. Your issue has been escalated to our repair/warranty support team. Here's your case number for reference: 7-7045000031923.
Ai
Hey all,
It's been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions from here, please feel free to create a new post.
accavazos
I did the same things as Geoff did, plus uninstalled the device from my app and tried to reinstall the device to app.  This issue is only affecting one of my thermostats.  Also, initially the thermostat wasn't picking up any networks and I had to type mine in.  Now, it's picking my network up but still it won't connect.
ai
Hi there
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 6-8694000031649.
Kindly,
Ai
Kenzdad
I’m having exactly same problem. This happened on the other thermostat and after 2 weeks of no thermostat to control AC, I got replacement thermostat two days ago. Now the second unit is having same problem. I’ve tried suggestions as others have described but not connected
thermostat does control system to which it is attached
ai
Hello
Ack! Sorry to hear you're also experiencing the same connectivity issues. Here's your case number as well: 3-3397000031609.
Ai
