Nest thermostat not keeping heat pump on
EdwardOverly
Nest thermostat brings heat pump on for less that a minute then shuts it down. Fan stays on and ac works fine.
EdwardOverly
Nest thermostat brings on heat pump for about a minute then shuts it off, keeping the fan on. Ac works fine.
Hi EdwardOverly,
I've duplicated your thread in the main one here. You’ll receive all updates on this issue on the main thread, and we recommend updating and checking this thread when needed.
Hello EdwardOverly,
Thank you for taking the time to let us know about your inquiry. I'd love to know more about this.
It appears that you're experiencing a power-related issue. Is this a first time installation? Could you please share with us photos of your previous and current thermostat's wiring? Also, check the power readings in the Technical Info if you have the Nest Learning Thermostat or the Nest Thermostat E, and the Equipment settings for the Nest Thermostat 2020 model.
Juni
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the futu
Juni
