Nest thermostat will not reconnect to wifi
Dizoomin
Can not reconnect to wifi, have restarted, reset   the nest and restarted the router.
David_K
I've linked a help centre article below that will help you troubleshoot this. Do let us know what happens when you try these steps? Try to be as detailed as possible so we know how best to advise.
Nest thermostat is offline
Ronhughb11
I have disconnected my router , restarted my thermostat, disconnected from my Google Home app but one of my thermostats will now not connect to WiFi..it shows on the dial that WiFi is being received?....Help
Ronhughb11
In addition after deleting the device, when I scan the QR code and input my Code on the back in "Setup" to get it to join my household, it will not "find" the thermostat ?  What do I do??
David_K
Next step would be try factory resetting your thermostat:
https://support.google.com/googlenest/answer/9247296
