11-21-2021 03:13 PM
I have finished installing a 5KW Chinese diesel heater in our sailboat. It works fabulous and it is really nice to have a warm cozy space. I am wanting to connect the Nest to control the heater in conjunction with the existing T stat.
First thing I’ve found is that the Nest works on 12 volts. I’ve got a three wire system with 12 v positive, 12 v negative and heat control.
Connected to Rh, W1 and C.
Anyone else used a Nest with an RV or a boat diesel heater and have any suggestions?
Next up is connecting through a wi fi hotspot.
Thanks!
06-24-2022 02:09 PM
Hi Steve,
I've no advice to give but just had the very same question myself. Have you succeeded and can you offer any advice to someone wanting to follow a similar path in their boat?
01-20-2023 01:56 AM
You have to change out your display with an aftermarket afterburner. You need one that had analog input controls, so the two upper priced models support that.
01-20-2023 06:13 AM
Just following up to say I've been running Nest with a Webasto heater from the late 90s successfully for 5 months now, it required a little bit of tinkering to identify the correct wires to interact with. The primary guides I followed were
https://www.youtube.com/watch?v=_Ezrqpf8WgM
and
Hope this is of some help to anyone interested though the afterburners are a solid choice otherwise!
01-20-2023 04:02 PM
Thanks for the insight! We're glad you are here to help the Community. We really appreciate it.
Archie
01-24-2023 04:03 PM
Archie
