05-21-2023 02:50 PM
My new nest thermostat is installed but won’t connect, I got it to connect a few time only to have it say the c wire has no power
05-27-2023 10:01 AM - edited 05-27-2023 10:03 AM
Hi Bjk661,
Thanks for posting here in the Community forum. A few questions: what type of Nest thermostat do you have? What is the exact error message you're getting on the Nest Thermostat? Also, can you help us with a wiring photo of your Nest Thermostat base?
Aside from that, please also gather your Nest Thermostat's power reading. If you have the Nest Learning Thermostat or the Nest Thermostat E, go to Settings, look for Technical Info, then select Power. If you have the Nest Thermostat 2020, go to Settings, slide down to Equipment, then tap Power Info.
05-30-2023 11:08 AM
Hello there,
I wanted to check and see if you managed to see the information I shared. Please let me know if you have any questions from here. I would be happy to assist and make sure you are good to go.
05-31-2023 11:16 AM
Hello Bjk661,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
