11-23-2022 01:32 AM
Hi All,I have just moved into a property with a NEST 3rd generation thermostat.I have had to reset it back to factory settings due to it being still connected to the previous owners.The problem I am having is there is No hot Water symbol on the system or connected to the thermostat,it says on the net that I need a NEST Pro id to add the hot water to the system but I don’t have one & don’t know how to get one.Any help or advice would be greatly appreciated.
11-23-2022 06:25 AM
Assuming I understand you correctly, there's need for any Nest Pro!
I think you may have set the system as a combi boiler.
Settings - Equipment - Continue - Pro Setup - Continue - System Boiler
Follow that through and make sure ''Control'' is set to ''On/Off'' and NOT to ''Not Connected''
11-23-2022 08:20 AM
Fantastic,thank you very much.That’s all sorted now.
11-29-2022 09:49 AM
Thank you for the help here, @Frustratedddd.
@Endeavour, I'm glad to hear that it's working now, but I wanted to ensure that everything was covered here.
Please let us know if you have any other questions or concerns.
12-02-2022 11:46 AM
Hi Endeavour,
12-04-2022 02:13 PM
Hello Endeavour,
Chiming in to check If you have any further questions or concerns, please let us know as we will be locking this thread in 24 hours.
