08-25-2024 03:38 AM
Hi
i have 3 nest thermostat
one of them stopped working so I removed it and reinstalled it . Can’t get entry key . Keeps sayi internet issue. But that can’t be as the other thermostats are are working with the app 😖
08-28-2024 08:49 AM
Hi Shah786,
Thanks for posting. I'm sorry to hear that you are having this situation with the Nest Thermostat that is not connecting to your app. But don't worry, I can help. In this case, I just need to ask for some information to better assist you:
I understand that you are having this situation with the WiFi connection on your Nest Thermostat, please check this:
You can check the "Can't connect Nest thermostat to the app" article for detailed information.
About the entry key, please first connect the Nest Thermostat to the WiFi network and then follow the instructions to find it:
You can check the "Get an entry key to connect to the app" for more information.
Please let me know if you have more questions. I'll be more than happy to help.
Jenny
