12-27-2021 01:22 AM
Got a new nest thermostat. Worked great for two days. All of a sudden no power and supposedly all wires are disconnected. Any advice?
12-28-2021 08:10 PM
I have the same issue any solutions??
12-29-2021 08:49 AM
So if all your wires are showing disconnected it's a problem with the furnace or heat system rather than the thermostat. For me, my control panel cover had fallen off triggering a safety switch. Easy fix that I should've. He ked before posting but our system is not as accessible as it should be. Might also check and make sure your drip pan isn't flooded.
