11-18-2022 12:55 AM
Hello all
I am just doing some research. Does the Openherm software work with heat only boilers (Worcester Bosch Greenstar 8000 life) and with multi zone heating within a property. The easy controller that Worcester have doesn’t support multi zone so I am just looking at alternatives.
Many thanks
T
11-20-2022 04:59 AM
Hi there, @Tristan1
Thanks for reaching out. The OpenTherm feature is not compatible with zoned heating in general, regardless of the boiler or thermostat. You can get one thermostat for each zone and go with the On/Off mode for it. There's not much we can do in this case.
11-23-2022 02:46 AM
Hi @Tristan1. Just checking in, is there anything else we can assist you with at the moment?
11-25-2022 02:50 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
