01-02-2023 05:30 PM
After patching wall where i installed Nest Learning Thermostat (3rd Gen), I took off the display unit to paint the wall. I left the base unit on and put painters tape around it. A bit of paint got through the tape onto the black rim on the base unit. I was able to scrape and wipe off most of it.
Does anyone know where the sensors are on the base unit and whether a little paint on the rim would affect the sensors?
Thanks in advance.
a month ago
Hi esquire1113,
Thanks for posting.
Make sure that you do not paint on the displays of your devices. A little paint on the templates or bases of your Nest Temperature Sensors will not affect the performance of your devices.
Mel
4 weeks ago
Hey there esquire1113,
Mel
4 weeks ago
Thanks Mel, you've answered my question.
4 weeks ago
Awesome — glad to hear that this is cleared out. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
