05-23-2022 07:52 AM
My nest thermostat keeps going dead. I do not have a C wire and believe after 3 years of draining and recharging has beaten up the ion battery to where it wont hold a charge for very long. I have come across the nest power connector to hopefully solve my C wire problem. I have a separate Ac unit (Rc, Y, G) and a Radiant heat/hot water unit (Rh,W). My question is can I hook the power connector to just my heating unit. Will the connector still give power to the thermostat even when I am only running the AC unit during the summer. The instructions of the power connector only say for heat only, ac only and heating/ac unit but i am assuming being a combined unit.
05-23-2022 04:22 PM
Which Nest Thermostat do you have? I hope it's the Nest Learning Thermostat.
The Nest Power Connector will work just fine but you want to set it up on the cooling side and not the heating side. Follow the instructions for the cooling only and connect the R wire on the Poer Connector to the Rc (R) terminal on the A/C. Connect the heating wires to the W and Rh terminals of the thermostat.
05-26-2022 10:12 PM
Hey slim12269,
I'd like to jump in here and check if you've seen Patrick_Caezza's response. Let us know if you need more help by replying to this thread.
Archie
05-27-2022 03:11 PM
Yes its a 3rd gen. Power connector just came in today. Gonna give it a shot this weekend. Thank you so much for your quick response.
05-27-2022 07:03 PM
Hey slim12269,
Gotcha — keep us posted.
Archie
06-08-2022 05:36 AM
Hello aatienza, if my air handler does not have a c terminal will this power connector still work?
07-28-2022 09:39 AM
Hi slim12269,
Sorry for the delayed response here, but I wanted to jump in to see if you got this sorted out or if you were still needing some help. If you're still working on this and need some guidance, let me know and I'll be happy to work on this with you.
Jeff
08-04-2022 05:03 AM
Hey everyone,
I'd like to jump in here and check if you've seen Jeff's response. Let us know if you need more help by replying to this thread.
Thank you for your help, Jeff.
Ryan
08-05-2022 10:34 AM
Hey all,
I wanted to check in, and ensure everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours.
06-02-2022 11:03 AM
Hey Patrick,
Sorry to make sure I get this right. I am connecting the Y and Rc wire from the thermostat to the grey wires of the power connector. Which of the white wires from the power connector are going to the air handler? For my heater, the wiring is staying the same Rh and W from the thermostat directly to the heater correct?
