12-19-2021 06:14 AM
My lin only reads 20 or 20 MA. Will my nest e work if I charge the battery off line?
12-19-2021 07:32 AM
It should show Volts 24-30 V AC if you are in USA. Put a meter set to AC on R and C wires see what you measure or do the test using the Nest menu and it should tell you the volts.
