Problems with startup
winklertom00
My Nest learning thermostat keeps going to "need to shut down in order to charge the battery"  What do I need to do?
@winklertom00 ,
This sounds like your Google Nest Learning Thermostat is not receiving power from your HVAC equipment to maintain its battery. Check the power input from the Setting on the display.  LiN should be around 200mA.
The Cooling Wizard
