RC and RH were jumpered. Will my Nest thermostat work? Or was I suppose to get the Next Learning?
rcalayo
 Here’s a pic of how the old thermostat was wired. I installed a Nest Thermostat but am not confident and read I should have bought the Nest Learning because RC and RH are jumpered.
DaveLister
Your system has a single R wire. It can be plugged into either the Rc or Rh terminals. Do not install the jumper on the Nest thermostat. If you'd like to verify this for yourself, use the compatibility checker at https://store.google.com/us/widget/compatibility/thermostat. Mark that you have both Rc and Rh. It will ask you on the next screen if they are jumpered. It will then tell you that the Nest Thermostat, Nest Learning Thermostat, and Nest Thermostat E should work with your system. Also see https://support.google.com/googlenest/answer/9250973 for more info.
I also notice there is a blue wire in the picture that isn't attached to anything. It's possibly a C wire but you should check if it's connected on the other end as it may or may not be necessary.
I appreciate you taking the time to respond to my post. It was very helpful and I’m good to go. Many thanks DaveLister.
zoeuvre
As we got our resolution here, I'm going to mark this thread as complete. I'll be locking this thread if we won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
All thanks for your help, @DaveLister and Jake.
Hey rcalayo,
Thanks for the helpful reply DaveLister.
I wanted to check in and see if you managed to see DaveLister's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
