Rads at full power?
Wakko101
The instructions for the nest thermostat say that you should put your radiators on the highest heat but is this really necessary? Can I set the rads to be at a lower temp on the boiler or will that interfere with how the nest system works? Thanks.
EdwardT
Hi Wakko101,
Thanks for reaching out. I'd love to know more about this. What type of Nest Thermostat do you have? Also, where are you located?
Edward
EdwardT
Hi Wakko101,
Edward
EdwardT
Hi Wakko101
Edward
