08-25-2021 09:40 AM - edited 08-25-2021 09:40 AM
Original Poster: Benny Rodriguez 9700
I've tried moving the red wire to rc and rh but both give the no power message. On the 3rd photo is the recommended wire setup which I have tried but kept getting a delayed message. Tried adjusting it and now I keep getting a no power error of E73 or E74.
08-25-2021 09:41 AM - edited 08-25-2021 09:42 AM
04-01-2022 12:47 AM
Not just the battery. Can be the pan full of water activating the float switch turning off the nest and thus the ac.
04-19-2022 12:42 PM
What CUKahle has mentioned is right, there are times that the only cause is a clogged drip pans or it's already full of water. You could check that out and make sure that filters are also clean.
Ryan
05-31-2022 03:01 PM
Hope this helps!
Kind regards,
Ryan
