04-08-2022 03:56 PM
Building a shop house with 3 zones of in floor heat which is the main heating for the house and shop. I will have a furnace in the house to heat when the in floor heat isn’t needed and to run the ac also. Is it possible for the nest to run both systems in 1 zone which would be the main zone?
04-19-2022 02:50 AM
Hey Zumakcfarms,
Thanks for reaching out and we're sorry for the delay.
Based on the description of the system you're planning to install, it is recommended to have your HVAC technician or a Nest Pro to check and help you install it.
You could also check out this link to know if your system could be compatible with Google Nest Thermostat.
Ryan
05-17-2022 04:01 PM
Hope this helps!
Kind regards,
Ryan
